Transponders to check for installation | SatelliteGuys.US
dgordo
324
Chicago
When installing a triple LNB dish which transponders should I check the signal strength on for 101, 110 and 119 satellites?
I check transponder #1 & #2 on 101 #8 on 110 and #26 on 119. I understand the locals come off transponder 26 here in the Omaha area. At least that what I've been told.
your dish should be pointed using the #1 transponder from the 101 satellite. Once this is in, the others are gravy. You should be able to get a signal between 86 - 90. Then set your polarization (tilt) to what the ZIP code setting directs and you should be VERY close for the 110 bird.
New Tivo for me :)
DirecTv to combine Latin American Corporations
