transponder/ spotbeam | SatelliteGuys.US
No_Brains
226
Princeton, WV
i have a question about the spotbeams... if i "move" i know that there are just a few options about the cities that you can move to that are not spotbeamed...
but can you move to one that is spotbeamed.. i mean is it possible..
and if yes ... how can you tell if it will work
any help is greatly appreicated
If you have a dish looking at the satellite where the questioned spotbeam is located, you can still see if you will get decent signal strength by going to the point dish screen and changing to the satellite and TP that the particular spot beam is on and it will tell you how much signal it sees.
That's great advice except that nobrains hasn't told us where he wants to "move" to. He could be living under a different spotbeam, and get a great signal strength on that transpoder, yet still not be able to receive the programs he wants.
Folders in Ext hard Drive
Eastern ARC DMA Lookup Tool
