Transferring Video | SatelliteGuys.US
Transferring Video
lewisjd
4
What would be the simplest way to get video from my 522 to my pc? Real time stream? There has to be a better way?
Hi lewisjd, welcome to SatelliteGuys.US. :)
Unfortunately, realtime playback & capture is the only way at the moment to get video off the 522. I doubt we'll see any other means. There is a slight chance they will give a software upgrade to enable the USB port, but solely for connection to the Dish Pod.
Rawr! I was doing some reading and I just figured that out. That sucks! You would think they would make it easier. Back to the drawing board!
Maybe if they do activate the usb port for the DVR portable then someone will be able to make a device enabling it to intercept the signal to go to a hard drive or PSP or something else.
625 vod question
6ft dish install questions
