Transferring Timers using a 54.x remote | SatelliteGuys.US
jwalter007
2
2
Usa
I'm swapping hoppers and working on transferring data from old to new one.
I'm following the instructions but the timers transfer via the remote won't work for me.
I noticed it says "timer transfer can only be completed using a 20.x or 21.x remote."
My remote is the 54.3 voice remote.
I assume that's why I can't get it to work.
Am I out of luck or is there some other method.
You're using the wrong one, Go into Tech Tools and click on Restore Settings
Local channel help
Auto Hop not working Prime Time Anytime
