I have a 722k on order to replace my 622. Is it possible to use the 2 way remote to transfer my timers from my 622 to the 722k? Thanks!
It worked for me using the remotes that came with the 722K to move from 722 to 722K.
The instructions for Backup and Restore are @ Tech Portal : Remotes : 20.0 IR
Select Backup from the lower left menu.
On the 722 remote push menu menu next and follow the on screen prompts using the 722K remote.
This didn't work on my 622. When I press the INFO button the receiver rebooted within a few seconds and when I went back to the screen is still told me no information had been exchanged.
You have to use the 20.0 remote that comes with the 722K to save settings. It worked for me.
Well now all it does is the light dance on the remote, then reboot my receiver....
Yay, another dish idea that doesn't work.
Yea I'm starting to think that eveyone who says "It worked for me" must be full of crap.
Limited time offer
