If he would try to take your 40.0 remote, tell him you bought it to replace the original that went bad. You might want to keep using it over the 52.I'd use an EHD. Hopper to Hopper transfers, if they work at all, might take days. The installer isn't going to do that. Make sure to keep your 40 remote or transfer your timers before it goes away.
Get an external hard drive and transfer all your recordings over to it well in advance to the tech visit. He won't wait for transfers to finish. Some may leave the old receiver for you to finish transfers but I wouldn't count on it.Currently have Hopper with Sling, wanting to upgrade to new Hopper 3. Will the install tech be able to copy my recording to the new H3 while he is here, or will I need to use an external had for this?
Not sure I remember, but I don't think so.Does the backup to the remote save favorites lists?
I have an external HD I use on my laptop, if I use that to connect to my hopper w/sling and transfer my recording to it, the copy to my new hopper 3, will I then be able to take it back to my laptop, format it, and continue to use it in my laptop as an external drive there?
But you can use a powered hub with that USB powered EHD to make things right.A portable EHD powered only by the USB connection is not recommended by Dish. Dish recommends a desktop EHD with it's own external power supply with capacity up to 2 TB.
Not recommended means " don't call us". I use a straight usb drive with no issues. (But there is probably a reason they don't support it, like heat ).But you can use a powered hub with that USB powered EHD to make things right.
Don't forget to backup your shows to an EHD.Just contacted dish to upgrade to hopper 3, tech supposed to be here tomorrow (5/9) between 12:00-5:00!![]()
Yes, usually that is.![]()
That's OK, I can live with that. There's really only one long list that I don't want to have to create on the new Hopper if I don't need to.BTW, the Favorites lists are saved, but not their names. At least, that's what happened when I replaced my failing HWS with a replacement. Did it twice and same thing happened both times.
I recently returned a bad Hopper. The Tech in replacement receivers, said Dish had a way to transfer your recordings . I got the impression he was not supposed to talk about it?Currently have Hopper with Sling, wanting to upgrade to new Hopper 3. Will the install tech be able to copy my recording to the new H3 while he is here, or will I need to use an external had for this?
Limited time offer
