Tp at Gal28 @ 89w | SatelliteGuys.US
Tp at Gal28 @ 89w
carlospr43
967
12
US
Morning Everyone!
I'm receiving a heavy signal at 11918 V 30000 but my Nfusion HD can't download what is in there. Anyone knows what it is?? Or if I need to enter PIDs manually?? Thanks
Lyngsat has it listed as a Hughesnet data stream.
here is the PAT
Code:
updatelee@silverstone:~$ dvbsnoop -nph -adapter 1 -n 1 0x00
dvbsnoop V1.4.50 -- http://dvbsnoop.sourceforge.net/
SECT-Packet: 00000001   PID: 0 (0x0000), Length: 52 (0x0034)
Time received: Sun 2010-06-13  08:40:14.721
PID:  0 (0x0000)  [= assigned for: ISO 13818-1 Program Association Table (PAT)]
Guess table from table id...
PAT-decoding....
Table_ID: 0 (0x00)  [= Program Association Table (PAT)]
section_syntax_indicator: 1 (0x01)
(fixed): 0 (0x00)
reserved_1: 3 (0x03)
Section_length: 49 (0x0031)
Transport_Stream_ID: 1088 (0x0440)
reserved_2: 3 (0x03)
Version_number: 0 (0x00)
current_next_indicator: 1 (0x01)  [= valid now]
Section_number: 0 (0x00)
Last_Section_number: 0 (0x00)
    Program_number: 0 (0x0000)
    reserved: 7 (0x07)
    Network_PID: 16 (0x0010)
    Program_number: 28005 (0x6d65)
    reserved: 7 (0x07)
    Program_map_PID: 32 (0x0020)
    Program_number: 28105 (0x6dc9)
    reserved: 7 (0x07)
    Program_map_PID: 33 (0x0021)
    Program_number: 4010 (0x0faa)
    reserved: 7 (0x07)
    Program_map_PID: 35 (0x0023)
    Program_number: 4020 (0x0fb4)
    reserved: 7 (0x07)
    Program_map_PID: 40 (0x0028)
    Program_number: 28001 (0x6d61)
    reserved: 7 (0x07)
    Program_map_PID: 36 (0x0024)
    Program_number: 3999 (0x0f9f)
    reserved: 7 (0x07)
    Program_map_PID: 41 (0x0029)
    Program_number: 4030 (0x0fbe)
    reserved: 7 (0x07)
    Program_map_PID: 39 (0x0027)
    Program_number: 11 (0x000b)
    reserved: 7 (0x07)
    Program_map_PID: 42 (0x002a)
    Program_number: 20500 (0x5014)
    reserved: 7 (0x07)
    Program_map_PID: 43 (0x002b)
CRC: 212585530 (0x0cabcc3a)
almost none of the PMT come through, no NIT and no SDT
pidscan shows
Code:
updatelee@silverstone:~$ dvbsnoop -nph -adapter 1 -s pidscan
Transponder PID-Scan...
PID found:    0 (0x0000)  [SECTION: Program Association Table (PAT)]
PID found:   16 (0x0010)  [SECTION: Network Information Table (NIT) - actual network]
PID found:   43 (0x002b)  [SECTION: Program Map Table (PMT)]
PID found:  300 (0x012c)  [SECTION: DSM-CC - private data section  // DVB datagram]
PID found:  400 (0x0190)  [SECTION: DSM-CC - private data section  // DVB datagram]
PID found: 8191 (0x1fff)  [stuffing]
the 0x10 there isnt really NIT, its bunk info
you could try 0x12c for vpid and 0x190 for apid, but dvbsnoop reports them as datagram, even though they dont look valid for that either.
0x12c is aprox 30Mbit/sec and 0x190 is aprox 2Mbit/sec
Coolsat 6000 Prem to Wireless N
For Amusement Only
