Toshiba 65HM167 HDMI port not working | SatelliteGuys.US
LOBO2999
823
Cumming, GA
I have a toshiba 65HM167 & one HDMI port is not working , there are 3 HDMI ports on the T.v the are in line with one another , so I would thank they are on 1 board ( not sure) I have tried other boxs, Blu Ray DVD players and other HDMI cables and it just wont work, it says no singal. The other HDMI ports work fine. I have even tried a hard reset of the T.v and still nothing. HAve look on the internet but found nothing there to help.Hope someone here might be able to.
Thanks!
You can get a hdmi switch if you need more than one port. This will allow you to hook up a blu ray and cable/ satellite box on the same tv hdmi port.
You can also get an AV system that uses hdmi so you can hook up everything you have on one tv hdmi port.
That's about all you can do if it's out of warranty, unless you want to fork out the dough to replace the board. That will not be cheap.
S~
S~
New Screen for FP 3D?
DMR-EZ47V and U-Verse HELP
