Topeka Fox 43 | SatelliteGuys.US
Topeka Fox 43
drwatson618
512
204
Anyone with Topeka's locals knows how horrible KTMJ Fox 43 is. Does anyone know if there is an option to get a distant HD for Fox only since it isn't available in HD? I believe the only way to receive it in HD is through Cox or AT&T. Unfortunately the only way to pick it up via antenna is on 27.2 which is also SD. I'm sure I know the answer to my question, but I thought someone might know something I don't. While I'm on the topic, what about the CW in HD as well.
You're right, you wouldn't qualify for distant hd. Not only that, it doesn't exist anymore for dish subs. Looks like you could be under multiple spotbeams. Have you thought about "moving"?
I've thought about "moving". I probably should since I can get the rest of the locals in HD via antenna. It really doesn't matter that it doesn't exist anymore for Dish subs because even though it showed up as an HD channel, it never was really in HD.
722k crashes -- infant mortality?
Replacing 622 with 211k - have a question
