Titanium Satellite ASC1 DiSEqC 1.2 Positoner - Firmware Update 20140930v1 | SatelliteGuys.US
  • Thread starter Thread starter Titanium
  • Start date Start date
  • Replies Replies 0
  • Views Views 971
Titanium
AI6US
7,694
9,182
Meadow Vista, Northern California
New and Improved ASC1 firmware is now available for download - 20140903v1 at: http://titaniumsatellite.com/updates
Important Notice: This firmware can only be loaded with ASC1 Loader/Editor version 1.8. Once this firmware is loaded, only Loader/Editor version 1.8 and higher will read and write Satellite Lists.
  • Modify - Continuous Move Mode Voltage: The M1/M2 motor voltage is now fixed in the continuous motor move mode. Motor Ramp In/Out is eliminated to address compatibility issues with AJAK HH motors and custom high count sensors circuits.
  • Modify - Relay Reset: The Reed sensor may land in either an open or closed (high/low) position at the end of a motor move. The Reed sensor may start in either an open or closed (high/low) position at the beginning of a motor move. This may result in a sensor count being added or dropped depending on the Reed switch position setting. The sensor relay is cleared to prevent over/under single count errors.
  • Add - Count Sampling: Sensor pulses sampled 10x
Thank you for your continued support of the ASC1 and for your feedback to make it even better!
F\T service? Or F/T service? What's That??!!
GEOSATpro SL2PLL issue
