Tip from me... | SatelliteGuys.US
Tip from me...
  • Thread starter Thread starter SatAdam
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
SatAdam
261
I thought I would give back a little to the place, since you guys have helped me so much ;)
When installing a motor, do not depress the "reset" button if it is off it's reference mark ("0"). Even though you are having problems, they are your problems with a poor job of alignment, not the motor's.
This will cause you to get mad and factory reset the STB, before you remember to download your channel list. Your morning will be filled with lots of blind scanning.
After you delete the channel list, you will realize that the reset button simply slid the "center" of the motor's software over. After you give yourself a "duh" slap to the forehead, you'll quickly figure out how to fix it and get the USALS working again.
Then you scan....
Thank You for your support. (Yea, those guys helped too.)
...Then you scan some more.
Dvb-s2
Nexus-S and ATI Radeon PCI-Express Card
