Tilt angle is wrong | SatelliteGuys.US
Tilt angle is wrong
FantasyChannel
169
I'm looking on my Sony and Samsung receivers for tilt angles for zip code 84014. Sony says tilt is 92. Samsung says it's 86. One of these is wrong, any idea?
There are no manuals I can find online that have the pages of zip codes and tilt angles for DIRECTV.
Try the difference, 89, then you just have, at most, 3 degrees either way to lock it on in. Those numbers are not (meant to be) exact, just close guides.
Those numbers also assume a perfectly level installtion.
And anyone who has installed anything either in or on your home knows, nothing is perfectly level.
When I installed my old triple LNB one angle was supposed 36 degrees. Ended up being 44.
"it's not really a rule, just a guideline"
what Dish is it, i bet i have a tilt guide FOR THE DISH, let me know. i'll do some digging, unless someone has that link handy, LOL sorry can't remember the post it was in.
It's the standard 18X20 Triple LNB Dish - Phase III
Install question, ungrading to HD
A Call to DTV
