chapelrun said:both are showing zero here. Others showing good strength.
70 miles west of Washington, DC, cloudy, VIP211K
61.5 TP 29 just came back - strength 55 but Name Not Acquired
77 TP 13 is still zero
dbs2000 said:I check signal strength every day, including the diagnostic menu that ckecks 4 TP per SAT and TP29 on 61.5 has been out daily for about 10 days. Have not checked today. Cannot tell you about 77 since 1 am on 119/110/61.5 mixed arc. I hope that helps.
Just a note is that my signal on 61.5 has increased about 10-15 points in the last week or so. I have 80's on about 8 TP with a 43" dish
Yeah I was checking the Status page that lists four "home" TPs per sat. I actually have both Arcs set up with a 1000.2 and a 1000.4, respectively. While running the checks on RA just for the heck of it I noticed those TPs that were zero. Doesn't seem to affect any channels though. When I get a chance I'll see what channels (if any) are on those TPs using Thelist or lyngsat.
None if the "home" TPs on 72.7 or the WA says seem to be exhibiting this behavior.
Btw, you probably already know this, but the mixed arc 61.5/110/119 setup is now missing most of the HD channels.
Sent from my iPhone 4S using SatelliteGuys
Limited time offer
