Thinking of upgrade to 625, but can this be done? | SatelliteGuys.US
bnewt
1,486
548
Shepherdsville, Ky
I want to use the tv2 out to feed several other tv sets, including my main set. It is an older set that doesn't have enough inputs so I use the rf input. I want to use the tv2 out since it is stereo. That part is simple enough. I also want to connect the 625 to a dvd recorder. I want to do this via s-video from tv1. Since I am unfamiliar witht the 625, anytime I want to record something from the satellite dish to the dvd recorder I want to use tv1 & anytime I want to record to the hard drive I want to be able to use either tv1 or tv2. Is that possible?
I'd suggest not worrying about a DVD recorder until after you record on the 625. After you watch a recorded program, you may decide you don't really want a hard copy of it anyway. IMHOm you're kind of making things difficult for yourself and not using the 625 as designed for.
Dish CEO Office fails to honor verbal contract
Mpeg 4 Upgrade nightmares! What would you guys do?
