Things that make you go hmmm... | SatelliteGuys.US
jacksonb
Canada
I have had some trouble with my dish lately in that a number of the channels break up every 10-15 seconds... the thing that's weird is that when the program screen or info screen is up, it stops.
My smart-a** friend tells me its the flux capacitor. :) Does anyone have any better ideas?
Did you try one or all three of the following rebooting processes?
1)Power button reboot-hold down on receiver till the screen goes blue and the box reboots.
2)Smart card reboot- pull out smart card & reinsert.
3)Power cord reboot-unplug the receiver ,wait a minute and plug it back in.
If all else fails add dish home protection insurance for 5.99 a month and then either get a tech out for 29.99 or replace the dvr. Once you have replaced the receiver, cancel the insurance. You can add the insurance and take it off as needed.
The info screen is locally generated by the receiver, so it should at all times be perfect if your connection between receiver and TV is good. But playing a channel off the satellite requires a lot more to work right, including dish alignment and good hardware from LNB down to the receiver.
Turbo Question
Yellow smart cards - which revision?
