If you use an old Dish box you can get 101, NASA & Angel One on it. I use my old 5000 for NASA and that has a Blue (Nagra 1) card
weird. My 5000 has upgraded as has the 811 (yellow card) and both get them just fine. They are FTA so any previously subbed box gets them
Yep, it's on 77w. I have a DBS dish pointed there for something else ITC and saw Nasa was on that bird.NASA is also ITC on the Eastern Arc in MPEG4
The DP301-013's never used a blue (Nagra1) cam. Only the legacy and DP301-005 and 010s models did. There was a 'forced upgrade' when Nagra2 system was rolled out that made the blue cam irds FW compatable w/N2 encryption specs. They also changed the channel maps at that time. The 013s FW like Tony's were already Nagra2 compliant.
All Nagra1 stuff has been abandoned for all intents and purposes, so should be fair game for manipulating to work for FTA applications. Nagra2 is about to be in the same catagory, as is 3rd party (non Nagra3 capable) FTA FW.
For a tinkerer, it would likely be possible, and legal to get an outdated Echostar equipment based system working for the FTA content on 119, but not without considerable reasearch and effort.
There is even a version of Pansat (STi5518) based FW, that was born of 'patcheyeware' but does not include the decryption routines for DN and is being designed and re-wriiten for true FTA service for STi5518 based Echostar and DTV irds.
Yes DTV is DSS, not DVB, but again it's a function of the tuner chip and the values written to it's registers. Yes the DP5XX are 5518 based too, but I've not seen anything on development for them.
The author has focused on modifying Pansat FW to make a DN 301-013, also STi5518 based into a true FTA dvb receiver. The base code for the SoC system is fine, but there are a number of commands, tuner chip registers and remote codes that must be re-mapped, due to fundamental peripheral design differences. The 301-010s are LS2000 based and not code compatable.
Not full featured, or state of the art, but for the tinkerer, a definate challenge. I would be curious to see if it would function on C band. In theory, it should if properly configured, unless the 301 front end has additional bandpass filtering that normal FTA boxes do not, or there are tuner registers that get overlooked in the remapped code. As a dedicated, fixed satellite, single lnb setup, it would be hard to beat.
Sounds like the Cuban modification project that was around in the 2002-2004 era. Did you have to do some trace cutting and jumpering to the tuner chip area to get it to work on DVB? That would (should) still be usable for NASA and Angel One on 119. It's a shame they encrypted the music channels now. It would have still worked for them now too. If I had to venture a guess, I'd say that FW was based on a dump of a Blackbird.Thank you Melgarga, very interesting info, I have a Hughes Gaebo (STi5518 based), Long time ago I read about a procedure to convert it to FTA, I did it myself, I got Nasa on 119W and the other FTA channels there, but never can use that receiver on 123W or other birds...the reason: tuner latch on SR:20000. I disappointed and put the box in the garage collecting dust... then I started to look for real FTA devices, Pansats 2500, 2700, 3500 and a Coolsat.
While re-purposing a Dish receiver for FTA might be an interesting project for the fun of it, a real FTA receiver can do far more (move a motor, manipulate channel lists, etc.), and they're reasonably priced.
I never saw the file, or found enough info on it to make a determination. I had always presumed that it was based on BB 'pirateware', considering the time frame. It is reasonable to presume this considering that the BB FW would already have the decrypt routines present and the real task would be to convert the DSS mode parameters to DVB in the tuner chip, but I dont know that to be the case.Smith, P. wrote-
It was a hack of existing FW, that's why it poorly works. Also, for FTA the IRD must have system tables of each sat/tpm/ch in a flash or better in separate chip like thru FTA receivers.
Sure, that is true enough. $100 (or less now) should be well within the budget of anyone in this hobby, but as magnigyro said the cost factor is incomparable when they are 5 bucks at a resale shop or free from the apartment maint guy that is cleaning out a skipper's apt. I've got 4 or 5 around here and bet I dont have 10 bucks in the lot. I gave $1.00 for an 013 at a garage sale that had a N2 card that hadnt expired! It lasted about 2 weeks.Tron wrote -
Limited time offer
