testing ploaritys on feedhorn | SatelliteGuys.US
vassho
71
After restoring a centerline feed horn
I want to make sure its working right before i put in on the dish
Can i test it by hooking it up to a receiver and switching polarities to make sure the servo is working right and my polarity are right
I almost think i can but need to make sure before i do it
any help would be appreciated
I know you can test the servo by doing this, as I have done it in the past. But, the only way to know if the polarity is right, is to mount it and check afterward. I'm sure, but not positive?
What satellite?
Satellite Dish Crane in Action
