Testing formatting | SatelliteGuys.US
Testing formatting
Not open for further replies.
Ok - confirmed it...
If you use the preview function, it previews correctly as-per what you entered, but then it re-formats your post eliminating the blank lines. See attached pic:
Shawn
That bit me in the butt and I didn't know it was a bug.
And bug it is, sinice it's not logical (regardless if it's documented or not).
Is there a fix?
I sometimes preview to see if I have things working right, and sometimes I don't.
Having that inconsistency is annoying.
Well, FWIW the Basic and Std editors both re-format on preview. The Advanced one seems to solve the problem.
Thanks for the tip Scott!
Shawn
Yea, the basic editor is pretty bad.
Ya need the the standard one to do decent editing.
I hadn't bothered to try the advanced one yet, as I was happy with the middle version.
Thanks for the info.
Testing advanced now.
edit: Basic | Standard | Enhanced
No problem, this new software has so many bells and whitles that it is hard to find things. :)
A lot of folks are reporting bugs which are actually features and they just need to know where to go to select the way they want things. :D
Ugh - the advanced editor is annoying - lol. I hate not seeing the tags.
I'll just Post / edit as a work around.
Shawn
Time to Edit your comments.
New Feature!
