tech question | SatelliteGuys.US
tech question
mdram
4,082
810
Md
ive got sirius in my truck, the wife would like it in her jeep liberty
what will hook up to the factory radio? can a kenwood tuner work?
id rather not fm modulate
mdram said:
i do believe it is
If its sat ready and its the factory radio you could have a dealer install it and pay out the nose or if Sirius makes a connect and play kit like XM does you could use one of those. I checked Sirius's website and all I see are radios listed by head unit manufacturer. You probably better off buying a plug and play like the sportser and using an aux input on the radio it will sound better then fm and be much less then having a dealer do it.
Edit: I did find this http://jeeppartspeople.com/searchpr...61&year=04&productdesc=Sirius+Satellite+Radio
just foudn the great deal at sirius i can get a starmate replay with home and car kit for 39.99 with a 6 month activation
so that may be what i do
sounds like a good deal to me. you may want to look into an aux input for the jeep so you do not have to use FM
I have no issues using the FM with my Sirius, it actually sounds better than my tape adapter I was using.
O and A taking over for Roth?
NAB's Rehr Attacks Satellite Radio
