I am sure it is an IP spoof as Scott runs linux and apache web-servers (even though out of date)
Just as a quick question; are you running the latest firmware on your router?
Nothing, but I have seen others report this issue to vBulletin support, so I figured I would give you their answer.P.S. I just _have_ to know, what does what server software Scott use have anything to do with syn flooding or spoofing?
192.x.x.x IS non-routable, it is his NAT that take care of the routing here is a quick read for you on RFC1631[2]: The LAN ip is also a RFC1918 address which are usually not routable over the public internet, and most ISPs do egress filtering, and most firewalls (such as iptables) can be, and usually are configured to not allow incoming from RFC1918 addressess into an outward facing interface from the outside, so spoofing as one of these ips would be likely futile.
Nothing with the spoof, but Linux 2.4.17 and up have SYN protection built-n to the kernel, but he is way behind on apache.P.S. I just _have_ to know, what does what server software Scott use have anything to do with syn flooding or spoofing?
Norton and McAfee are the WORST two home use products available. Not from a protection standpoint, just as far as resource pigs. After your protection expires give AVG a whirl, it is much lighter and smaller.ah, to that I should have added before that I am specifically using Symantec NIS (full suite) 2007 version, complete with the latest available updates.
RONTFLMAO, my father-in-law bought a new PC MONDAY and called me because he could not connect to the Internet via DSL out of the box, his Norton firewall disabled the access. Don;t get me wrong, at one point Norton was God, now they plain suck. I think I still have my NDD 4 around here.I have absolutely NO, ZERO, NADDA issue with Norton and resources. And until the day comes that i do, I'll chose to stay protected. I tried free once and got burned; never another issue since.
Good point, this should help keep you on the line ... perhaps damaged too.Sounds like a setup issue to me. BUT this is not the topic of the thread.
Limited time offer
