TAN TV | SatelliteGuys.US
TAN TV
toucan-man
2,693
25
Wisconsin
Can someone with a TAN TV subscription use the supplied receiver with a DiSEqC to add another dish to pick up some FTA channels?
in the menus on the receiver does it show a diseqc option?
(or do you not have one yet)
I guess was hoping to get an answer before I would go over to this guy's place. It is someone from the community who I don't know well, but he mentioned they had TAN TV at home (his wife is Korean), but his eyes really lit up when I mentioned all the stuff on G19. I think TAN is their only television at the moment, and he says two of the channels in that package are dogs, guess he's living with only 2 good channels. I mean, I feel his pain.
OK did some looking on the tantv site (well their mother site...the one in english) ;)
according to the site, there are 2 receivers
8800 & 6200
The 8800 DOES have Diseqc option and so does the 6600
from the 8800 guide
Press ?/? keys to select between the following items, press ?/? or 0…9 to change its value:
SAT No.
You can select the satellite number by pressing ?/? keys. The total number is 32.
SAT Name
It shows the satellite name. You can change the name by pressing FAV+, FAV- keys.
LNB Freq.
Select the L.O. Frequency that is set to antenna. You can select the LNB frequency of 5150, 9750, 10600, 10750, 11250, or 11300 MHz by using the ?/? key. If the required LNB frequency is not available then enter the frequency using the 0…9 keys.
22kHz
Set to OFF to select dual-LNB or set to ON to select two antennas connected to a 22kHz tone switch.
DiSEqC
According to the option and position of DiSEqC switch, you can select from A to D of DiSEqC and turn it OFF.
6200 guide see attached picture below
here is where to get the pdf's of the manual
GUIDE AND MANUALS | home2us
noticed on their site they sell a dual LNB antenna for 97 & 101
That's good news, I should maybe have him call his dealer in Wisconsin and see what they would charge to do an upgrade. I guess they're happy enough with the service, but might be much happier with all those free channels.
mun2
Northern Satellite Corp NSC 18-1
