TAN 1 - 2 - 3 on AMC 4 | SatelliteGuys.US
ikki
922
12
Minnesota
Did they just turn the encryption on these.
12118 V 30000
Up until today they always came in.
Tan 1
Tan 2
Tan 3
They did it about a week ago, as far as I know.
That's when I got a dish big enough to aim at 101W
Got it all peaked up and nothing on the channel.
I checked Mike's list and it was gone from there as well.
So yeah, scrambled. It had a bunch of the shows I had been looking for.
Be thankful you've got IA.
I can't even get that where I am usually.
I just checked that mux with TSREADER.
Those channels are not scrambled. They just aren't there.
They are still listed in the SDT, but they are NOT listed in the PAT/PMT streams, and there are no A/V PID streams associated with those channels.
Simply gone, not scrambled.
I had assumed that they were only added to 12118 V 30000 temporarily due to the signal strength problem that 11860 had with the switch from AMC4 to AMC2 back in March:
http://www.satelliteguys.us/free-ai...-satelliteguys-help-readings-amc2-4-101w.html
SD TEST PATTERN (HD same?)
where u find a circular c-band lnb??
