All,
I received my Tailgater today from Claude and wanted to post some information for those interested.
Attached are the pictures from the un-boxing and initial setup.
Setup was as easy as you can imagine. Put the tailgater on a level surface with a clear view of the south. Connect the included 50' coax cable to the Tailgater and your 211K receiver running software version L499 or higher. Plug your receiver into the wall and wait a couple of minutes.
The first screen you see is the Portable Antenna Setup Screen. Simply choose your state and select scan. Then you will see the switch installation check, acquiring signal, and downloading program guide screens.
Once these are complete, about 10 minutes, then you are watching TV.
I did some quick test ESPN, ESPN2 no issues. Changing channels takes about 5 seconds. I then tuned into my locals. Complete Signal Loss 015 Error. WHAT???
I then check my locals in SD and they are fine. So I decided to get some readings to compare the Tailgater with my main dish.
Tailgater
Sat - Trans - Signal - Channel
129 - 03 - 5 - Locals HD
110 - 23 - 55 - Locals SD
110 - 07 - 33 - ESPNHD
129 - 30 - 31 - ESPN2HD
119 - 13 - 25 - USA
1000.4
129 - 03 - 21 - Locals HD
110 - 23 - 66 - Locals SD
110 - 07 - 64 - ESPNHD
129 - 30 - 53 - ESPN2HD
119 - 13 - 76 - USA
My Zip Code is 72751
Obviously with a signal strength of 5, My hd locals are not going to come in. Not sure what I am going to do about that. Figure I will give Dish a call and see what they have to say.
Let me know if you have any questions regarding the Tailgater and I will try to answer them.
Tailgater
119 - 13 - 25 - USA
1000.4
119 - 13 - 76 - USA
