t5- how to get strong tp levels when some work? | SatelliteGuys.US
shahdad
30
Im trying to get t5 with better lock
Some of the channels come in but not others.
a few of the tps i get a max 30% but the other ones that i want come in at only 10%-15% which is no good for getting a clear channel
now could this be due to bad weather? those tps are weaker and cant penatrate through clouds?
also, about 10 meters from where the dish is there is a tree and the branches over hang and fall in front of the dish, could this cause the lack of signal?
i cant make sense of it, b/c it cant be the above resaons, can it? if i can get some tps that are strong and channels are clear, why dont the other tps come in at the same level or at least a little more?
ive also played with the dish, with very very small increments, up down and left right and where i have it at is the best using the tp that come in at 30%. any little movment drops the signal down to 18-20%
how can i improve the other tps?
any insigt would be great,
thanks
30 is way low for t5. I have only done a couple there but always got 70 to 80's.
I am going to say it the tree branches that hang over the dish. the signal cannot go though stuff like that. Can you move the dish or cut the tree?
ya thats what i thought, but what i dont get is that if the tree is the problem, then why do some tps come in? would the branches not block the whole signal not allowing for any tps to come in?
The branches equally degrade all transponders but the link budgets for the transponders are all different. In other words they are running at different power levels. On almost any satellite when you go through the various transponders you can see some pretty large swings in signal strength on the reciever end. Cut down the branches and limbs and you will see a big difference. IA-5 is not a strong satellite to begin and needs all the help it can get.
problem solved, you were right, it was the braches
moved to new location with no branches
does your cable company transmit hd as hd lite?
The HD Lite Revolution is Here!
