SWM Config Question | SatelliteGuys.US
SWM Config Question
winesmile
19
Ran out of room on a splitter to add a 5th HD DVR.
I'm going to add a MSPLIT8R1-03 1x8.
Config will be:
Add second RG-6 to second SWM output at dish location and pull to basement and connect to input of the 8-way splitter.
Connect the single RG-6 to the new splitter and I'm good to go.
Question is: do I need to connect the new splitter to the old in order to get power from the power injector? Would I use the "red" output of the new splitter?
All I know is that the SWM can only handle 8 tuners. You're adding a 5th DVR which equates to 10 tuners.
You need to get a SWM16 setup to a legacy LNB (4 outputs).
HR24's no HDMI, service call until Wednesday !?
Cant request room to Record HR24
