swm and other questions | SatelliteGuys.US
bigike74
2
Dallas
Hi, am totally blind and your forums are easy to use for me with my screen reader. . I am wondering is there a way to use the new h24 with out utilizing swm. Also, in the sl5 configuration the two side cart l&b's picked up what satelites, and is there other sl5 configs with out the side cart. Is the sidecart reliable and can it receive high deffinition. Is the satelite sl3 the same shape as the sl5, and can you just slip that 5 l&b on up in the sl3 dish. And last but not least, is there one of the satelites dishes that gives the best signal?Thanks for taking my questions
Don't know much about dishes but the 24 models are the same as all of the others as far as compatibility is concerned. They don't need SWM unless you're doing a MRV set up with DECA.
Welcome to the forum!
:welcome
Yes with a slimline 3 or 5 lnb. You would need a bbc inline.
The 5lnb picks up the 99,101,103,110,119 satellites.
New sl5's aren't sidecars, but an all in one lnb like this.
Reliable? They can be, but Directv is replacing them.
HD, yes they do get HD
sl3 had less "horns" on it. so no its a little different shaped.
Yes, I really find best results using SWM3 lnbs with the slimeline dish. BUT, you might need a SWM 5 lnb if you area requires it, and that one is just fine as well.
swm with switch
Hi, is the max that a swm will allow 8 outputs and what kind of switch do you have to use
SWM back to Slim
Eurovision 2010
