switching recurring timers to different tv | SatelliteGuys.US
phillycreamboy
40
I have a 622 recevier and I set several recordings during the day to record. My roomates have the tv that is tv2. The recording I have sometimes record on TV1 and sometimes on TV2. When they are home they can't watch tv if something is recording unless they go and watch it on TV1. Is they an easy solution to this problem? A way for them to move the programming to the TV1 that is not in use?
i have the same problem, its driving me crazy. my roomates keep canceling my recordings because they show up on their tv and their recordings will record on my tv.
That is the problem I have because if you set the preference to TV1 then all of the recordings will record there. Is the an "on the fly" way to switch the tuner? OR....if they cancel the recordingon TV2 does it pick up immediatly on TV1?
For what you are trying to do you really need two separate DVR's but that would defeat DISH's logic.:)
Uplink Activity For WeD. May 10th 2006
Tech Chat Screen Caps...
