Switching Ku for C Band | SatelliteGuys.US
TimLones111
453
Canton, Ohio
Hello:
I've had the same setup since beginning in FTA last year-Fortec Star Dynamic Reciever with Fortec 36" dish and Sadoun DG 280 Motor. My question is, would I be able to switch out a Ku Univeral LNB for a C-Band LNB by just taking one off and putting the other on?...And assuming it is connected correctly, would i get anything on C-Band at all with this setup?
I say the answer is, "sort of"
There are numerous threads about mini BUDs. search to see... A 36 " dish is on the small side of the mini BUD catagory.
A C-band LNB is much larger. So, you will have to buy or make a suitable holder. For an offset dish, you need a conical scalar ring too.
You can get strong transponders with mini BUDs, but at best they are experimental.
I tried C-band with a one meter dish. It was fun to play with, but for watching TV it was kind of disappointing. Many of the TP's would not come in. Whether a mini BUD is good for you depends on your goals...
Do you have another dish for Ku and just want a separate dish for C? Because you could always go with the BSC621-2 for both C and Ku. I purchased one of these and they work great.
Hello:
Check this out: http://www.satelliteguys.us/free-air-fta-discussion/175747-c-band-90cm-dish-worth-story-pics.html
My attempt to catch the NYE ANALOG feed on G-17 ku
Top 10 Reasons i am into this hobby
