Switching from E* to D*. Can I use existing mast? | SatelliteGuys.US
peterl1365
SatelliteGuys Guru
141
I have a Dish 500 with Dual LNB's. I'm switching to DTV and getting a Phase III dish. Will the DTV dish fit onto the existing mast? I want to pull the Dish 500 down before the DTV installer gets here.
Okay, thanks for the info. Line of sight is no problem whatsoever. This should make things a lot easier.
How frequently can I activate/deactivate receivers?
Tivo code???
