jrp SatelliteGuys Master Original poster Aug 24, 2007 6,103 434 Iowa Nov 30, 2007 #1 Is it possible to switch between user modes on the remote, or is it necessary to use the front panel of the 622 to do so?
volkodav SatelliteGuys Pro Nov 16, 2005 864 0 us Nov 30, 2007 #2 you have to do it on the box. there is no button on the remote
jrp SatelliteGuys Master Original poster Aug 24, 2007 6,103 434 Iowa Dec 1, 2007 #3 Thanks. I thought that was the case, but it is good to know for sure.
B birdo SatelliteGuys Family Sep 2, 2007 56 0 Dec 1, 2007 #4 If i may hijack a thread. I have the 722 and I can do the PIP split screen which is very cool. Is this something new to only the 722. My 222 on the other TVs will do the PIP but no the split screen. Is this correct.
Jim S. When someone asks you if you're a god, you say yes Lifetime Supporter Jan 2, 2006 5,803 1,558 FN11od Dec 1, 2007 #5 The 622 does split screen.
B birdo SatelliteGuys Family Sep 2, 2007 56 0 Dec 1, 2007 #6 Damn I wish it did it for the 222. I actually like that feature during Sunday football
