switch or quad output questions | SatelliteGuys.US
metalman29
3
I have a two receiver dish500 system (2 dual output LBNS, 2 sw-21 switchs, 301 receivers) that I installed myself. I now want to upgrade to 3-4 receivers.
Opinions on the following would be appreciated
- Would you used a quad output LNBS or go with a new switch to get up to 4 receivers? Seems as the quad is a little cheaper and no power requirement.
- Will I likely have to fine tune the aim after replacing two dual LBNS with one quad LNBS?
- Is there any preference to a SW-44 or an SW-64 in my system? Only SW-44 is listed in the installation manual
-Would you install the switch on the interior only? Old switchs are covered, but outside. Since 4 wires are now required, the same amount of coax would be necessary no matter the location of the switch. Is ther an advantage to having it nearer the sat or receivers?
Thanks for your time
Seeing you have 2 DP301s I recommend you go with a DP Quad should be available for less than $100. Far more reliable than SW-64 and newer technology that DISH should support further into the future.
$822.24 for my fist *E bill?
new Voom channels pic troubles..??
