Switch Issue after unhooking cable | SatelliteGuys.US
reseman5
17
I had to unhook the direct line from the Node to the Hopper this morning to remove an old cable for internet. After hooking it back up I keep getting an error message saying a problem has been detected with the satellite dish and to recheck the switch. Is there anything special on how the cable lines are fastened to the Node beyond just screwing back in? I'm at a loss for what the issue is.
Yes, when I do the check switch, it shows the Node: Not Connected, Switch: None, and Reception ERROR. It says something isn't installed correctly and there is no satellite signal.
Best place to sign up for DISH?
