Switch Box locations | SatelliteGuys.US
GOHAWKS
70
Sioux City,Iowa
I have a 722 and a 522, they are being fed by a dp34 switch, I would like to switch receiver locations.
Can I just switch box locations making sure that I plug the same receiver 1 and 2 input cables into the same spots on the receivers?
Would I have to do a switch check?
I'm changing my HD tv location and of course need the 722 to follow.
I'm working on swapping the 522 for another 722 but I hope this will do in the mean time.
I appreciate your time and idea's
thanks
yeah, that should work just fine. I would probably run a check switch just in case after the move, but its probably not necessary.
Also, keep in mind, that your tv2 locations will move as well.
Newbie question - Seattle area channels
sat.61.5,tp30-Garbage!
