SW64 Problem? | SatelliteGuys.US
SW64 Problem?
tdwatson
I am getting a signal loss on transponder 6 on two of my three receivers wich affects ch 174 215 214 191 and some other channels. One receiver I am getting no problems. I thought this might be a cable problem but one receiver is working just fine. Could my SW64 switch be bad.
:rolleyes:
It may need to be reset. Try unplugging all the receivers for at least 1 minute, and then plug in one of the problem receivers and do a switch check. Then add the others in 1 at a time. Good luck.
Cablevision running through 522 question?
942, Network HD, NFL HD....I don't want much
