sv8000hd Blind scan | SatelliteGuys.US
sv8000hd Blind scan
tobor26
23
Ottawa Ontario Canada
I have an sonicview 8000hd.I't's hooked up to a 33in dish with a invacom lnb,steered by a hh90motor.Lately when blind scanning on g18,or any sat,the reciever stops about 20% into the scan.It then flips to the settings page with no writting or anything filled in.On dtv scans it won't even start.Has anyone had this problem before?Should I save all my sat and channel entries and do a factory reset?thanks for any help. tob
Which firmware are you running?
I haven't had this issue but you can try a few things:
-turn it off and back on with the switch on the back
-reload the factory firmware
-check for proper ventilation/outside heat sources
-delete channels, transponders or satellites that you won't use.
I'm guessing the last one is your real problem. You probably just need to free up some space for further scanning.
Ribbon Cable for C Band Dish Expensive?
Satellite Beacons
