Surround Sound Question | SatelliteGuys.US
Mikemosun
18
I have a system hooked up to my D* and now i have a loud buzz coming out of my subwuffer.It was fine when i had comcast. The tuner works good if it wasnt for the loud deep buzz coming out of the sub.Any thoughts? Mike
Is it all channels? How about other speaks other than the sub? What happens when you do a speaker test do you hear it?
The one thing I notice going from Charter to D* was the sound is alot chrisper and louder so that might be the issue. Last it may be an issues with Receiver.
If it's a powered sub try using a "cheater" plug adapter. This plug does not have a ground, it helped my ground loop hum.
Thank for the info.I bought one of those cheater plugs and the humm is gone.You guys are the best.
Flat Cable & HD Signals
local abc hd /DNS. abc hd Portland, OR
