Superdish with 2 DP34 and 2 322 receivers | SatelliteGuys.US
jlnewt
I have a Dishnetwork Superdish with 2 TVs hooked up to DVR - they both work.
I have two TVs hooked up to a 322 receiver on a DP34 Switch - they both work.
I have a second DP34 swithc and a second 322 receiver hooked up but cannot seem to get this performing correctly. I get the error that one of the satellite inputs is not getting a signal. I have checked the connections and they are all tight. Any suggestions?
Yeah - swap receiver feeds between the first and second DP34. That will tell you if the second switch is getting what it needs.
ANother thing to do is swap the two 322's between their locations. That will tell you if the 322 is bad.
Can you upgrade from two 301's to a 522 or 625?
DP-34 Grounding Question...............
