Superdish LNB Question | SatelliteGuys.US
robroy90
Greetings,
I am considering the purchase of a Superdish (105), and I was curious to know about the LNB configuration of the 110/119 LNB. It appears from what I can see that the LNB for 110/119 slots only has a pair of outputs (1 for each).
So, my question is this:
Can I replace that LNB with a "Quad" LNB so I have 4 outputs? Is it even necessary? Or is this handled by the DP34 switch? I am just trying to determine what the optimal configuration of the dish will be, for both now and the future. Once I get this thing installed, I really don't want to mess with it again.
If someone could explain this and what my options are with the Superdish, I would really appreciate it. I don't mind spending the money for a Quad LNB now if it will give me greater expansion later.
Thanks,
Rob
The DP 34 Switch has 4 outputs. If you want more than 4 outputs, you can buy another DP 34 and hook them together to get 8.
/Benjamin
/Benjamin
superdish 121 install tomorrow hopefully
superdish plus snow fall = problem
