superdish 121 lnb + 33' dish | SatelliteGuys.US
xmad_manx
2
Hi,
Would hooking up a superdish 121 lnb to a 30' or 33' dish work, if not how about using those 3 lnb holders?
I think a 30 foot dish would work very well! :D
A 30" or 33" dish would come close to the recommendation (IIRC) of a 36" dish. You might get a slightly less reliable signal. I wouldn't know how to attach to LNB to the dish without more information.
So hooking up 3 lnbs or a superdish lnb assembly to a 30' would serve as a superdish, what switches I should use? I have a 4900 receiver.
If you go with DishPro, you would need a DP34 and a Legacy adapter sicne the 4900 is Legacy
If you go with Legacy, you can use a KU band LNB, a Legacy Twin and a SW21 (easiest in my opinion)
being able to choose location in room
$50 discount for new Dish Network customers!!
