Superdish 121 + Dish Pro Plus | SatelliteGuys.US
clonedbhandar
49
Is it possible to have a superdish 121 and have dish pro plus....currently I have a DP34 switch and my 721 receiver takes up two of my ports...I wanted to add a fourth receiver but don't want to lose my 721. How would I go about doing this? i know I will have to get a DPP44, but what about the DPP LNBs for 110, 119, and 121...are those required?
The LNBs don't look like the regular LNBs that are used....
Also I only have the superdish...so only three cables coming out...what would i do for the 4th cable.
2nd DP34 or a DPP44. The 2nd DP34 will give you 4 more additional outlets. Swapping out the DP34 for a DPP44 will give you 2 additional outlets depending on the receivers that you may add and the ability to add another sat location to your system.
some people have used the DPP44 with only 110/119 so they can use the separator to run one line from the switch, hook up the separator and use it for a dual tuner (so they only need one line)
Remember that the bird order is sometimes important, so avoid possible issues by connecting the 119 feed to input port #1, 110 to #2. This applies to the DP34 also.
Received my DPP44 switch today, hooked it up (119 - #1, 110 - #2, and 121 -#4) and took it to my 721, used the splitter and worked like a charm.
Thanks for all the help
Dish Pointing
What is the 522 tv2 RF output?
