Superdish 105 with Rec 3900 Running | SatelliteGuys.US
  • Thread starter Thread starter vmaxept
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
vmaxept
27
Pikeville, TN
I wish to thank the pros and semi-pros on this list. My SD105 install went almost perfect. I got a powered sat meter from ebay, sure made alignment easy. Bought the RG-6 and tools etc from a list member shop, got the DP-Leg power adptr on ebay. I peaked all sats with the meter. I did 105 first then 119/110. I peaked 119/110 with the rec connected in the house- used FSR to talk me in. I got about 125 sig on them. Had no 105. Ran check switch and it came in. I get about 70 sig. I get great local channels from Chatt TN now.. other then 2 snowy channels. I did not re-peak for 105 since it appears sig strength of 70 is very good. Very pleased with the setup. Now I have to think about HD.
Roger R
Whay dish will most likely lose me soon
What is sat 119 for?
