Supercast Week 2 Issues Adobe AIR | SatelliteGuys.US
cb35
113
Hi Guys
Wonder if anyone has the same issue - I logged in to the supercast stand alone program around noon - and it was streaming the pre game shows fine - then around 12:45 it wouldn't stream any more video - probably due to demand on the system - I logged out and tried to log back in - no luck - was getting every error in the book - nothing was working - both the browser based program and the AIR program
now I have installed and unistalled the AIR program - it still won't work. It launches and is in my task bar at the bottom of the screen but it won't respond. I have tried alt+tab and right clicking......I get nothing. I have tried everything - the browser program worked around 3PM but you can't pull up full screen on that program.
wondering if anyone heard of a fix for this issue or its a software issue on AIR & D* end. I am using Vista Premium - last week I had no issues at all.
ok doesn't sound like you had an issue
anyone else run into this - any forums you know of to troubleshoot supercast adobe issues?
here is the fix - dbs talk guys helped me out big time
try tapping alt then space then M and then any arrow key. The window should now be stuck to your mouse to be moved someplace on screen nicely.
my program was running off screen somehow - way to the left - so when I did the above and arrow right it magically appeared
I haven't tried out SC:Air yet. I unexpectedly got 2 HDTVs for my house (long story) so instead of my TV + Laptop configuration, I just have TV + TV. Is the SC:Air much better than last year's web version with Slingbox?
I registered just to let you know that this is what finally fixed my problem!!! I had no idea WTF it was for the past 4 weeks.
Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Cartoon Network West ch 297 Oct 8th
Los Angeles subscribers/installers, I could use some help!
