Super Joey on Duo Node | SatelliteGuys.US
hp2009
10
2
usa
currently I have one hopper and one Joey on Duo Node where 3 lines coming from dish Lnb and one cable connected to host duo node then that cable goes out to moca And connect to node and client port connected to Joey room and host port cable connected to hopper room.no issue things working great but need more tuner so
I have ordered super Joey now one cable need to add next to duo node (host and two client open),where this cable goes ? Host or client
How about on moca just keep same setting as client cable goes to Joey room?
Do I need integrators which I donot have unless it comes with super Joey ?
Can I use spilter instead of integrators if I need ?
Hank
Hank
With a single Hopper, you don't need a dual node, and in fact, the dual node is taking the third line from the dish that needs to go to the Super Joey's integrator.
You should replace the dual node with a solo node.
Here is a document that shows many different connection possibilities. Page 11 and 12 are probably closest to what your system will look like.
http://www.satelliteguys.us/xen/attachments/hopperjoeysystem_jobaid-pdf.95719/
Thanks for reply currently with one hopper and one Joey has Tap outside box to connect inside so if I am correct I do not need tap with supper Joey and one hopper.
Just connect super Joey from integration adv
Client to outside wire with inside room
Same as hopper connect from host (solo )to direct to outside wire with inside room
Hank
can anyone "play to end" movies on external drive or nas?
HWS record double
