Super Home Node and DTVPal | SatelliteGuys.US
IlliniChuck
75
I currently have a 722 and 322 in my home from Dish Network. I also have an OTA hooked up to a super home node. In 2 of my rooms I only receive analog channels from the OTA.
I went out and purchased the DTVPal and it works great for picking up the digital OTA channels. However, I can't watch my DISH programming unless I use the remote that it came with and utilize the analog pass through button. I really would like to keep it simple and have 1 remote and avoid using the DTVPal remote.
Any suggestions?
you can use your Dish remote to run the Pal. The Pass-through button will be whatever button is in the same area of the Dish remote. (upper-left)
sorry, I am pretty bad at this stuff. I don't really know what that means. I followed the instructions that are in the 722 instruction manual (codes: 722 and 742) that are associated with DISH products.
Sorry for being so lame, but I really do appreciate your help.
well I'm finally home. not sure how much help I'm going to be though. I just grabbed both of my Dish remotes, pointed each one at the Pal and controlled it without doing a thing. Power on and off, menu features, pass-through, everything. If you have UHF/IR remotes you might have to figure out how to setup one of the AUX buttons to control a Dish receiver. I will try to investigate this further this evening.
Any suggestions?
What is a super home node?
Lost my program guide
Why does Dish keep adding/removing MOJO on a TEMP channel?
