sub channels | SatelliteGuys.US
sub channels
larry55
Cutting Edge
Jan 15, 2009
1,253
145
dothan al
I have the am21 tuner and it will add not the bounce channel which is 34-2 or cw which is 23-2 it in hd ota but in sd on direc. I talk to a tech about updates their dma so the am21 will add these channels in the guide .she has no clue what I was talking about.
Good luck with that ...
You can try running Buffalo NY (14201) as a secondary zip. You will have the Bounce guide on 23.2 and a weather station guide on 34.2, but it should give you those two channels. No way to match 34.2 to a Bounce guide by running a secondary zip. Many other ways to go if Buf. doesn't work.
Any deals going on for new customers?
Contract end is near
