Stupid question - How to tell which rev the 811 is... | SatelliteGuys.US
blfuller
32
Washington State
On my 811 system info screen there is 2 lines that have the following:
SMART CARD S0070221271-93
DNASP102 REV 281
SOFTWARE P284LABD-N
What info do you go by to see if you have the latest revision, the smart card info that actually reads REV 281 OR is it the Software line that reads P284LABD-N? If you go by the software, which would be most logical it would tell me I have revision 2.84. Anyone in the know want to straighten me out on which is correct? Thanks.
DNASP102 REV 281
SOFTWARE P284LABD-N
The software line. P284 is the latest. You can always check the following website to see what the current version is.
http://www.dishnetwork.com/content/customerCare/technical/software_versions/index.asp
NightRyder
Dish and TIVO??
Jvc Hm-dsr100du E* D-vhs?
