When stripping RG6 Quad, do strip through the first layer of foil and braid and then bend back the second layer of braid?
Richmond VA, channels 6, 8, 12 kept down "ghosting"....would have been easier just to move those channels!VIPERS-PIT said:You have to have a QUAD shield prep tool and Quad shield fittings or you are wasting your time. Well I think quad shield is a waste anyway. Its just something to brag about. Ive never seen any improvement using it.
kdarcangelis870 said:I didn't install the quad shield. It was installed when my house was built. I needed to know because I am adding a fourth room to my directv system.
VIPERS-PIT said:Thats cool but it would be easier to just run RG-6 for the new run. It will work fine with the quad shield and save you money. If the cable is pre ran and does not have fittings on it, drive by the local cable company at 7 am someday and offer a tech 10 bucks to put fittings on the cable for you. It will be much cheaper than buy the fittings and compression tool.
Limited time offer
