Strange recording issue. | SatelliteGuys.US
budda
596
100
Oconomowoc
DVR 722K. So far only OTA but that my be because that is the source I record from most. Say there is a 1 hour show,It will say 1:05 as the recorded time. As you view the recording. it works till say 30:00 min., left could be less could be more. Then recording just ends. Says a full hour but no content. Software 750. Wondering if its software or HD? Or something else?
How many recordings are like this? Have you reset the receiver and tried to view it again? Can you try setting up a timer on a non OTA channel to see if the same thing happens?
What's your signal strength on your ota channel? Sounds like it lost the ota signal.
But when it comes to recording a program from one of your local network stations, your better off using the Dish feed. That frees you up to watch another program of your ota antenna.
It has happened on OTA and Sat channels, Like USA network, or TNT. On the OTA channels I dup the recordings cuz the kids will bump them from time to time, and no this is not the case with these. And it will be fine on the other.IRD..My OTA signal is around 92 at the lowest and 100 on most. My dish feed does not provide HD for locals because of LOS issue if the channels come to 119 110 129 it will work but I think they are on sat 72 or 68, zip is 53066. Thanks for replies.
So when did KBS World (9850) become KBS World Espanol
It would be nice if...
