Strange looking feedhorn | SatelliteGuys.US
Corrado
2,443
334
Hudson Valley Region, NY
Anyone have any ideas about this double ended looking LNB on this dish?
I'm hoping to take this one home someday.
Thats a "SeeVee" c-band only, I used to use 1 back in the 80's good working feed, even had a C & Ku SeeVee feed their 1st model that they made.
yeah i looked up seavey but the newer ones only show a dome on the bottom of the feedhorn, so i didn't post about it
would be nice to get a upclose picture of it :)
the other dome was a protective cover that would cover up the servo motor conections, the servo had 3-screws on it where you put the wire in then tighten up the screws, like you do a actuator today.
when I got that feed (this is maney moons ago) that is when I changed from a LNA & down convert to a LNB an if I remember right put a 75 degree on it, was the lowest you could get back then.
also in the little dome will have a antenna that looks like a butterfly that the servo motor turns, now a servo motor of today will NOT fit on that feed, it takes a servo with a square drive sticking out.
My Birdview Project, need HELP!
Strange message on my DSR922
