Strange Joey 2.0 Remote Issue | SatelliteGuys.US
WiCkeDuDe
1,554
304
Utah
I had a Joey 2.0 installed with my Hopper 3 a few weeks back. I hate the 52.0 remote so much i bought some 40.0 remote instead. On this Joey 2.0 the 52.0 remote worked just fine with the old phillips magnabox tv.
I unpaired the 52.0 remote and paired the 40, then set it up with the tv. There were three codes that all worked but using the 40.0 remote if I pressed the power, volume or mute the remote sends the command twice. Hence the tv turns on then off, mute then unmute, etc.
I tried another 40.0 remote that worked fine on another tv and it does the same thing on this tv. I then tried the 52.0 again and it does NOT do this and works perfectly.
Has anyone else ever seen this strange behavior and know a way to solve it?
Thanks!
unpaired and then it does it again as soon as I pair it to the Joey. 52.0 remote still works fine. ughhh
Anyone using Darbee with Dish HD?
Hopper Limit series recordings -- BUG
